Bionic Geeks
Electronics turned up side down
    [ROM] Restore to unrooted GB from ICS (AT&T)
    Share
    Post  Admin on Sat Sep 22, 2012 11:06 pm
    by thecubed
    What is this?
    This is a PH39IMG.zip that you flash via HBOOT to restore your phone to stock unrooted Gingerbread shipping ROM. This will also remove Clockwork Recovery
    Quote:
    Why should I use this/care?
    If you've updated your phone to the Ice Cream Sandwich build that AT&T pushed out OTA, or flashed your phone manually, you may at some point in time wish to go back to Gingerbread.
    If you do, you'll find that the PH39IMG.zip and RUU that you would have previously tried to use don't work, since ICS updated your HBOOT.
    This is essentially a "return to warranty" kit. This doesn't remove the "*UNLOCKED*" flag on HBOOT, but it will allow you to return to some semblance of stock just in case.
    Quote:
    How do I use this?
    Your bootloader must be unlocked to flash this.
    Download the file, put it on your external SD, and boot to HBOOT. Accept the update when prompted.
    If you're trying to return your phone to AT&T for warranty, you should probably also re-lock your bootloader also ("fastboot oem lock")
    Please note!
    This is not for HTC Raider / Velocity / Generic Holiday users!
    This restores the shipping HTC Vivid ROM for AT&T.
    Quote:
    Downloads
    Restore to unrooted Gingerbread Stock:
    http://goo.im/private/iomonster/htcvivid/roms/restore-gb-from-ics/PH39IMG.zip
    Main website:
    http://forum.xda-developers.com/showthread.php?t=1529669
      Current date/time is Sun Jan 21, 2018 7:37 am
